Exports the content of a table entity in CSV file format.
command bar: tableexport
context menu: Export Table...
: tableexport
Select Table to export: click a table entity
The Export Data dialog box displays:
If started from the context menu, the Export Data dialog displays right away.
Select a folder. |
Type a name for the CSV file. Default name: <table_name>.csv |
Exports the cell data and creates the CSV file. |
Aborts the TableExport command. |
Procedures
Defining the list separator character
Table - creates a table entity in the drawing through a dialog box.
-Table - creates a table entity in the drawing through the command bar.
Tablemod - modifies the properties of a selection of table cells.
Tabledit - edits the cell content.
TableStyle - creates and edits table styles through the Drawing Explorer - Table Styles dialog box.
