WipeOut
Creates wipeouts, blank areas in the drawing.
command bar:  wipeout
menu bar:  Draw | WipeOut
toolbar: Draw |
: wipeout
Frames/Polyline/<Start point>: (Pick a point, or enter an option.)
Next point: (Pick another point.)
Undo/<Next Point>: (Pick another point, or type U.)
Undo/Close/<Next Point>: (Enter another point, or type C to end the command.)
Use the DrawOrder command to move the wipeout in front or behind other entities.
Start point
Specifies the staring point of the wipeout frame.
Pick a point or enter x,y coordinates.
Next point
Specifies the next vertex of the wipeout frame.
Undo
Undoes the last segment.
Close
Closes the frame.
Frames
Toggles the display of the wipeout frame; prompts you:
Enter display mode: OFF/<ON> - type OFF or ON.
  • OFF - turns off the frame. When the fame is off, the wipeout cannot be selected.
  • ON - turns on the frame.
Polyline
Uses a closed polyline to construct the wipeout frame; prompts you:
Select a closed polyline - pick a closed polyline. Only polylines composed of line segments are accepted.
Delete selected polyline? Yes/<No> - determines whether the polyline is erased:
  • Yes - erases the polyline.
  • No - does not erase the polyline.
Procedures
To create a wipeout using points
To create a wipeout from a polyline
To control the display of the edges of wipeouts
Grips Editing
Wipeouts can be edited directly through grips:
  1. Select the wipeout. Notice that it has one grip at each vertex.
  2. Drag a grip to stretch the vertex.
DrawOrder - changes the display order of overlapping entities.
PLine - draws polylines.
RevCloud - draws revision clouds.
