Prompt Menus
BricsCAD commands often provide several options. These options appear in the status bar or command bar and also in a prompt menu, which initially displays in the top right corner of the screen. Choose the appropriate option by clicking in the prompt menu.
Whether a prompt menu displays and its location is controlled through the PROMPTMENU settings variable.
Value
No prompt menus
1
Display prompt menu at user defined location (*)
2
Display prompt menu at top left corner
3
Display prompt menu at top right corner
4
Display prompt menu at bottom left corner
5
Display prompt menu at bottom right corner
(*) You can move the prompt menu by dragging it; future prompt menus will appear where you last placed it.
To control the display of prompt menus
  1. Do one of the following:
  2. Click the Settings tool button () in the Standard toolbar.
  3. Choose Settings... in the Settings menu.
  4. Type settings in the command bar, then press Enter.
The Settings dialog opens.
  2. Go to the Prompt Menu settings variable under Program Options > Display.
  3. Type prompt menu in the search field, then press the next button ()
  4. Click the down arrow at the right hand side of the prompt menu settings field, then select the option of your choice in the list.
NOTE
The PROMPTMENU settings variable is saved in the registry and therefore applies to all drawings.
