Overview
Parametric constraints are used to maintain relationships and control dimensions of 2D geometry.
There are two types of constraints:
In the example below:
Parametric constraints allow to:
Two versions of the same fully constrained drawing representing a roundabout
NOTE
It is recommended to first apply geometric constraints, then dimensional constraints.
When using constraints a drawing can be in one of three states:
Door Swing (Internet connection needed)
Bracket (Internet connection needed)
Commands and toolbars
2D parametric constraints tools sit on the 2D Constraints toolbar:
Command
Icon
ConstraintBar
Controls the display of the constraint bar of entities.
Constraint bars are always hidden when opening a drawing.
Delconstraint
Removes all dimensional and geometrical constraints from an entity.
Geometric Constraints
GeomConstraint
Applies geometric relationships between entities and/or valid constraint points on entities.
GcFix
Constrains points and entities at a fixed position.
GcCoincident
Applies a coincident geometrical constraint to two points or constrains a point to an entity.
GcConcentric
Constrains the center points of circles, arcs, ellipses or elliptical arcs to coincide.
GcCollinear
Forces lines or polyline segments to be collinear.
GcParallel
Forces two lines or linear polyline segments to be parallel to each other.
GcPerpendicular
Constrains two lines or polyline segments to lie perpendicularly to each other.
GcTangent
Constrains two entities to maintain a point of tangency to each other or their extensions.
The following entities are accepted: lines, polyline segments, circles, arcs, ellipses or elliptical arcs.
GcHorizontal
Constrains lines, linear polyline segments or pairs of points to lie parallel to the X-axis of the current coordinate system.
GcVertical
Constrains lines, linear polyline segments or pairs of points to lie parallel to the Y-axis of the current coordinate system.
GcSmooth
Forces a spline to maintain fluid geometric continuity with another spline, line, arc or polyline.
GcSymmetric
Constrains two entities or points to lie symmetrically with respect to a selected line.
GcEqual
Constrains arcs and circles to the same radius, or lines and polyline segments to the same length.
Dimensional Constraints
Dimconstraint
Applies a dimensional constraint to an entity or between constraint points on entities.
Converts associative dimensions to dynamic dimensions.
DcHorizontal
Constrains the horizontal distance (X-distance) between two points with respect to the current coordinate system.
DcVertical
Constrains the vertical distance (Y-distance) between two points with respect to the current coordinate system.
DcLinear
Constrains the horizontal distance (X-distance) or vertical  distance (Y-distance) between two points with respect to the current coordinate system.
DcAligned
Constrains the distance between two points or the length of a line or polyline segment.
DcRadius
Constrains the radius of a circle, an arc or an arc polyline segment.
DcDiameter
Constrains the diameter of a circle, an arc or an arc polyline segment.
DcAngular
Constrains the angle between two lines or linear polyline segments; the total angle of an arc or an arc polyline segment; or the angle between three points on entities.
DcConvert
Converts an associative dimension to a dimensional constraint.
