Command: XPURGE
X-Solids allows for the use and editing of native ACIS solids that are created with BricsCAD Pro or BricsCAD Platinum. They can be used in boolean operations to form composite solids, and once they are part of an X-Solids composite, they can be manipulated with the XSOLIDEDIT command just as any other X-Solids primitive, except that no parameters will be available for the ACIS solid for editing, as such data was not saved with the solid when created. Native ACIS 'composites', which have been created with boolean operations, fillets, chamfers, and/or slices will be recognized as single primitives with no editable parameters. X-Solids primitives and composites can be reduced to an ACIS solid with the XPURGE command.
