Command: XTORUS
To create an X-Torus
Do one of the following
Click the Torus
tool button (
) on the X-Solids toolbar.
Choose Torus in the X-Solids menu.
Type xtorus in the command bar, then press Enter.
The Create X-Solid Torus dialog displays:
(option) Select Radius or Diameter
from the option button of the X-field.
The option applies to both the torus (X-field) and the tube
(Y-field).
To define the Parameters of the X-Solid torus do one of the following:
Type the values in the Origin, X and Tube Diameter Y (or Tube Radius Y) fields.
Select a value in the drop-down list.
Click a Pick button
) to define a parameter in the drawing.
Click the Pick All button to define all parameters in the drawing.
(option) Click the Manipulate... button to move or rotate the X-Solid torus.
(option) Click the View... button to manipulate the view.
(option) Click the Preview button.
(option) Choose an After primitive creation operation to be executed after the X-Solid torus is created.
Click the OK button to create the X-Solids torus.
