General procedures to manage X-Hardware solids
To set the X-Hardware options
  1. Do one of the following:
  2. Click the Options tool button () on the  X-Hardware toolbar.
  3. Choose Hardware > Options in the X-Solids menu.
  4. Type xoptions in the command bar, then press Enter.
The X-Hardware Setup dialog box displays:
  1. Choose your preferences.
  2. Click the OK button to save the options.
To create a X-Hardware solid
  2. Click the All Hardware tool button () on the X-Hardware toolbar.
  3. Choose Hardware > All Hardware in the X-Solids menu.
  4. Type xhardware in the command bar, then press Enter.
The X-Hardware dialog box displays:
  1. Choose a specifications standard from the Standard list button: e.g. Euro.
    The choice of a standard limits the number of options on the next list buttons.
  1. Choose a category from the Category list button: e.g. Beam
    The choice of a category limits the number of options in the next list buttons.
  1. Choose a type from the Type list button: e.g. HEA-BEAM, EURONORM 53-62.
  1. Choose a size from the Size list button.
    Only sizes for the selected type are available in the list.
  2. To define the length of the X-Hardware solid, do one of the following:
  3. Type the length in the Length field.
  4. Choose a length from the Length list button.
  5. Click the Pick Points button ().
    The X-Hardware dialog box closes temporarily.
    You are prompted in the command bar to specify two points to define the length.
    After specifying the second point the X-Hardware dialog box reopens.
  1. Click the OK button to create the X-Hardware solid.
    The X-Hardware dialog box closes.
    The command bar reads: Insert point:
  1. Specify a point in the drawing.
    The X-Hardware solid is placed along the Z-axis of the current UCS.
    The length is measured along the negative Z-axis.
  2. Do one of the following:
  3. Specify a point in the drawing to place another copy of the X-Hardware solid.
  4. Right click to stop.
To edit a X-Hardware solid
  2. Click the Edit tool button () on the X-Hardware toolbar.
  3. Click the Edit tool button () on the X-Solids toolbar.
  4. Choose Edit in the X-Solids menu.
  5. Type xhardwarechange in the command bar, then press Enter.
The X-Hardware dialog box displays, showing the settings of the selected X-Hardware solid:
  1. (option) Choose a different standard from the Standard list button.
  2. (option) Choose a different category from the Category list button.
  3. (option) Choose a different Type from the Type list button.
  4. (option) Choose a different Size from the Size list button.
  5. (option) To modify the length of the X-Hardware solid, do one of the following:
  6. Type the new length in the Length field.
  7. Choose a length from the Length list button.
  8. Click the Pick Points button ().
  1. Click the OK button to apply the changes.
