To launch a X-Hardware command you can either:
Click the tool button on the X-Hardware toolbar.
Choose the command in the X-Solids > Hardware menu
Key-in the command in the command bar.
Icon |
Tool name |
Keyboard |
Bar |
xbar |
Creates a bar |
Bearing |
xbearing |
Creates a bearing |
Cross recess screw |
xcrossrecessscrew |
Creates a cross recess screw |
Hardware |
xhardware |
Repeats the last X-Hardware tool. |
Change |
xhardwarechange |
Edits a X-Hardware solid. |
Hex cap nut |
xhexcapnut |
Creates a hex cap nut. |
Hex castle nut |
xhexcastlenut |
Creates a hex castle nut. |
Hex flange nut |
xhexflangenut |
Creates a hex flange nut. |
Hex head screw |
xhexheadscrew |
Creates a hex head screw. |
Hex nut |
xhexnut |
Creates a hex nut. |
Hex slotted nut |
xhexslottednut |
Creates a hex slotted nut |
Hex washer nut |
xhexwashernut |
Creates a hex washer nut |
Key |
xkey |
Creates a key. |
Options |
xoptions |
Opens the X-Hardware Setup dialog box. |
Pem |
xpem |
Creates a pem. |
Pin |
xpin |
Creates a pin. |
Pipe |
xpipe |
Creates a pipe. |
Ring |
xring |
Creates a ring. |
Rivet |
xrivet |
Creates a rivet. |
Set Screw |
xsetscrew |
Creates a set screw. |
Shape |
xshape |
Creates a profile (e.g. HEA steel beam). |
Slot recess screw |
xslotrecessscrew |
Creates a slot recess screw. |
Socket head screw |
xsocketheadscrew |
Creates a socket head screw. |
Sprocket |
xsprocket |
Creates a sprocket. |
Square nut |
xsquarenut |
Creates a square nut. |
Thread |
xthread |
Creates a thread. |
Washer |
xwasher |
Creates a washer. |
Wing nut |
xwingnut |
Creates a wing nut. |
© Menhirs NV. All rights reserved. |
