The BricsCAD license activation always requires an Internet connection.
However, if your computer is not connected to the Internet, the license can be activated manually via another computer (which is connected to the Internet).
Do one of the following:
The first time BricsCAD is started - Go to next step.
When starting BricsCAD in trial mode - In the Free Trial dialog, click the Enter License... button.
When replacing or upgrading an existing license - In the Help menu, choose BricsCAD License... . The Licensing Information dialog box opens. Click the Modify... button.
The Activate BricsCAD
dialog box opens. Click the Activate
Manually... link.
The Manual Activation dialog box
opens.
Copy the full content of the Computer Hostid field.
With the Internet connected computer, go the Bricsys website.
In the Support menu,
choose My Account (login required).
Make sure you have the Bricsys account of your company which
contains the Volume license. Contact your Bricsys account manager
if needed.
The My Account page opens.
In the left menu, choose Licenses and support contracts.
Click the Manage... button of the V14 license you want to activate.
In the Host ID field, paste the computer host ID of the computer you want to install BricsCAD on.
Click the Activate
button.
A license file is generated and made available for
download.
Click the Download License
File button.
The license file BricsCADV14.lic is
downloaded to your default download folder.
Copy the license file to the computer you want to install BricsCAD on.
In the Manual
Activation dialog box, click the browse button (
Open the folder where you copied the BricsCADV14.lic license file to and select the
file.
Click the OK button. BricsCAD is launched.
NOTE |
Manually activated licenses cannot be deactivated. |
