DxfOut
Exports drawings in DXF format (short for "drawing interchange format output").
command bar:  dxfout
alias:  dx
: dxfout
Entities/Binary/Version/Enter decimal places of accuracy (0-16) <6>: (Enter an option.)
Entities
Exports only selected entities in the DXF file; prompts you:
Select entities to export - choose the entities to export.
Binary
Exports the drawing in binary DXF format; otherwise, the DXF file is in ASCII (text) format.
Version
Specifies the DXF version number in which to save the drawing; prompts you:
File version R2.5/R2.6/R9/R10/R11/R12/R13/R14/A2000/A2004/A2007 - enter a version number.
Caution: exporting to an older version can cause some entities or properties to be lost.
Specifies the accuracy of real numbers in the DXF file; enter a number between 0 (no decimal places) and 6.
Some CNC (computerized numerical control) machines require 4 decimal places in DXF files.
Export - exports drawings in a variety of formats.
DwfOut - exports drawings in DWF format.
