LightList
BricsCAD (Windows) Pro, PlatinumBricsCAD (Linux) Pro, PlatinumBricsCAD (Mac) Pro, Platinum
Displays the Drawing Explorer - Lights dialog window.
command bar:  lightlist
alias:  LL
menu bar:  Tools | Drawing Explorer | Lights...
toolbar:  Lights |
: lightlist
Menu bar
New
Edit | New
Starts the LIGHT command.
Delete
Edit | Delete
Deletes the selected lights.
Select in drawing
Edit | Select lights in drawing
Closes the Drawing Explorer - Lights dialog box.
Selects the light's glyph in the drawing; the light's properties display in the Properties Bar.
Rename
Edit | Rename
Edit the name of the light.
Select all
Edit | Select all
Selects all lights in the light list.
Choose Select in drawing to select the glyphs of all lights in the drawing.
ON
Indicates the light is currently switched on. Click to turn the light off.
OFF
Indicates the light is currently switched off. Click to turn the light on.
Light: Creates a new light.
Render: Calculates a photorealistic image of the 3D model.
Sunproperties: Displays the Sun Properties of the Active Viewport editor in the Drawing Explorer - Lights dialog.
GeographicLocation: Sets the geographic location of the drawing.
