MlStyle
Creates and edits multiline styles.
command bar:  mlstyle
menu bar:  Tools | Drawing Explorer | Multiline Styles...
: mstyle
Displays the Drawing Explorer - Multiline Styles dialog box:
  1. Details
  2. Editor
  3. Preview
Multiline Details
New
Creates a new multiline definition.
Type a name in the Name field. Spaces are not accepted in multiline style names.
(option) Select an existing multiline style, to be used as a template for the new style.
Click the Create button.
The New Multiline Style dialog closes. The new style is added in the Details pane.
(option) Type a description in the Description field.
Delete
Deletes the selected style(s).
Press and hold the Ctrl key to select multiple styles.
Used styles cannot be deleted.
Purge
Purges the selected style(s).
Load from mln file
Loads multiline styles from a multiline (*.mln) file.
Displays a file dialog box.
Save to mln file
Saves all multiline styles in the drawing to a multiline (*.mln) file.
Detail view
Switches to Detail view, when in Icon view.
Icon view
Switches to Icon view, when in Detail view.
The current multline style is marked.
Click the tile in front of a style to make it current.
Multiline Editor
Add
Adds a new line.
  • Specify the offset from the reference line (0).
    A positive offset creates a line at the left hand side of the reference line, a negative offset creates a line at the right hand side.
  • Specify the line color.
  • Specify the linetype.
Note: The number of lines and the offsets of used styles cannot be changed.
Delete
Deletes the selected line(s).
Press and hold the Ctrl key to select multiple lines.
A multiline style contains at least one line.
Fill
If selected, a solid fill is created between the outer lines.
Display joints
If selected, joints display between the various multiline segments.
Start and End caps
Closes the end segments of open multilines.
Settings:
Preview:
Mline - creates multilines.
Explorer - opens the Drawing Explorer dialog box.
