SaveAsR12
Saves drawings in DWG R12 format through a dialog box.
command bar:  saveas12
: saveasr12
Displays a dialog box with Save As Type set to "AutoCAD Release 11/12 Drawing (*.dwg)":
To save the drawing in other formats, click the Save As Type droplist.
Selects the drive and folder in which to save the drawing. Click the droplist to access additional locations.
Specifies the name by which to save the drawing:
  • Accept the default drawingn.dwg file name.
  • Enter another name.
  • Click the droplist to access names of previously-save drawings.
Specifies the format of the saved file. Accept the default (AutoCAD 2007 .dwg) or click the droplist to choose another format.
There are three basic formats:
  • DWG - drawing file.
  • DXF - interchange file (ASCII and Binary).
  • DWG - template file.
Includes a preview image with the drawing file. The preview is a bitmap (raster) image of the drawing's view at the time it is saved.
Saves the drawing.
Cancels the command; does not save the drawing.
Save - saves the current drawing through a dialog box.
QSave - saves the drawing without displaying the Save dialog box.
SaveAll - saves all open drawings.
SaveAs - saves drawings by another name.
Export - exports drawings in a variety of vector and raster formats.
