A command line tool that uses hard encryption to encrypt LISP files. BricsCAD supports this type of encryption.
NOTE: The tool is not delivered with BricsCAD. Download LISP encryption tool.
See the instructions included in the download.
Loading an encrypted LISP file works the same way as loading a normal (non encrypted) LISP file.
BricsCAD automatically decrypts the encrypted LISP file in order to be able to use it. This decrypted LISP requires protection. The BricsCAD LISP protection mechanism replaces the decrypted LISP by the word "PROTECTED" when the decrypted LISP code or parts of it are extracted at runtime to be printed to the command line, to a file or to an entity.
Tell me about...
Copying Code Examples from the BricsCAD Programmer’s Reference
Programming Overview of LISP (LISt Processing) Language
