vlax-2d-point
vlax-3d-point
vlax-add-cmd
vlax-create-object
vlax-curve-getarea
vlax-curve-getclosestpointto
vlax-curve-getclosestpointtoprojection
vlax-curve-getdistatparam
vlax-curve-getdistatpoint
vlax-curve-getendparam
vlax-curve-getendpoint
vlax-curve-getfirstderiv
vlax-curve-getparamatdist
vlax-curve-getparamatpoint
vlax-curve-getpointatdist
vlax-curve-getpointatparam
vlax-curve-getsecondderiv
vlax-curve-getstartparam
vlax-curve-getstartpoint
vlax-curve-isclosed
vlax-curve-isperiodic
vlax-curve-isplanar
vlax-dump-object
vlax-ename->vla-object
vlax-erased-p
vlax-false
vlax-for
vlax-get
vlax-get-acad-object
vlax-get-object
vlax-get-or-create-object
vlax-get-property
vlax-import-type-library
vlax-invoke
vlax-invoke-method
vlax-ldata-delete
vlax-ldata-get
vlax-ldata-list
vlax-ldata-put
vlax-ldata-test
vlax-make-safearray
vlax-make-variant
vlax-map-collection
vlax-method-applicable-p
vlax-null
vlax-object-released-p
vlax-product-key
vlax-property-available-p
vlax-put
vlax-put-property
vlax-queueexpr
vlax-read-enabled-p
vlax-release-object
vlax-remove-cmd
vlax-safearray->list
vlax-safearray-fill
vlax-safearray-get-dim
vlax-safearray-get-element
vlax-safearray-get-l-bound
vlax-safearray-get-u-bound
vlax-safearray-put-element
vlax-safearray-type
vlax-safearray-value
vlax-tmatrix
vlax-true
vlax-typeinfo-available-p
vlax-variant-change-type
vlax-variant-type
vlax-variant-value
vlax-vbabort
vlax-vbabortretryignore
vlax-vbapplicationmodal
vlax-vbarchive
vlax-vbarray
vlax-vbboolean
vlax-vbcancel
vlax-vbcritical
vlax-vbcurrency
vlax-vbdataobject
vlax-vbdate
vlax-vbdecimal
vlax-vbdefaultbutton1
vlax-vbdefaultbutton2
vlax-vbdefaultbutton3
vlax-vbdirectory
vlax-vbdouble
vlax-vbempty
vlax-vberror
vlax-vbexclamation
vlax-vbhidden
vlax-vbhiragana
vlax-vbignore
vlax-vbinformation
vlax-vbinteger
vlax-vbkatakana
vlax-vblong
vlax-vblowercase
vlax-vbnarrow
vlax-vbno
vlax-vbnormal
vlax-vbnull
vlax-vbobject
vlax-vbok
vlax-vbokcancel
vlax-vbokonly
vlax-vbole_color
vlax-vbpropercase
vlax-vbquestion
vlax-vbreadonly
vlax-vbretry
vlax-vbretrycancel
vlax-vbsingle
vlax-vbstring
vlax-vbsystem
vlax-vbsystemmodal
vlax-vbuppercase
vlax-vbvariant
vlax-vbvolume
vlax-vbwide
vlax-vbyes
vlax-vbyesno
vlax-vbyesnocancel
vlax-vla-object->ename
vlax-write-enabled-p
