Add3DMesh method
Adds a 3DMesh given the coordinates and mesh information.
Syntax
objectVariable = object.Add3DMesh(M, N, Vertices)
Where:
     object is one of the ModelSpace or PaperSpace collection objects or a Block object;
     M and N are Long integer variables representing the size of the mesh (the dimensions of the point array);
     Vertices are a series of Point objects specifying coordinate locations for each vertex of the mesh;
You can also input the number of vertices in each direction and their coordinates.
