Adds a cone given the center, base radius, and height. The cone is drawn as a 3dSolid.
Syntax
Where:
object is one of the ModelSpace or PaperSpace collection objects or a Block object;
Center is a Variant identifying the center of the cone;
BaseRadius is a double-precision variable representing the radius of the cone at its base;
Height is a double-precision variable representing the height of the cone.
Examples...
© Menhirs NV. All rights reserved. |
