AddEllipse method
Creates a new ellipse and adds it to the drawing.
Syntax
objectVariable = object.AddEllipse(Center, MajorAxis, RadiusRatio)
Where:
     objectVariable is an Ellipse object;
     object is one of the ModelSpace or PaperSpace collection objects or a Block object;
     Center is a Variant representing the center of the ellipse;
     MajorAxis is a Variant  representing the orientation of the major axis (the line which defines the longest distance across an ellipse, from one end to the other;
     RadiusRatio is a double-precision variable or number defining the major to minor axis ratio of an ellipse. A radius ratio of 1.0 defines a circle.
Examples...
AddEllipse method example
