Adds a group of entities to a block or selection set.
Syntax
Where:
object is a Block or SelectionSet object;
Entities is a selection set object to which the items are to be added;
DeleteOriginals is a Boolean variable (or value) indicating whether or not to delete the original objects.
TRUE = Objects will be deleted.
FALSE = Objects will not be deleted.
Examples...
© Menhirs NV. All rights reserved. |
