Adds a torus given the location, torus radius and tube radius. The torus object is created as a polygon mesh.
Syntax
Where:
object is one of the ModelSpace or PaperSpace collection objects or a Block object;
Center is a Variant representing the center point of the torus;
TorusRadius is a double-precision variable representing the radius of the torus (distance from center of torus to center of tube);
TubeRadius is a double-precision variable representing the radius of the tube.
Examples...
© Menhirs NV. All rights reserved. |
