AddVertex method
Adds a vertex to a lightweight polyline.
Syntax
Sub AddVertex(Index, Point)
Where:
     Index is an Integer variable (or value) defining where the vertex will be added in the lightweight polyline.
     Point is a BricsCAD Point object locating the vertex to be appended.
Examples...
AddVertex method example
