AngleFromXAxis method
Returns the angle of a line from the X-axis; The angle is measured counterclockwise.
Syntax
object.AngleFromXAxis(Point1, Point2)
Where:
     object is the Utility object;
     Point1  Variant (three-element array of doubles): the start point of the line;
     Point2 Variant (three-element array of doubles): the end point of the line;
