AttachExternalReference method
Attaches a specified drawing as an ExternalReference.
Syntax
objectVariable = object.AttachExternalReference(PathName, [Name], [InsertionPoint], [XScale], [YScale], [Zscale], [Rotation], [bOverlay])
Where:
     object is one of the ModelSpace or PaperSpace collection objects or a Block object;
     PathName is a string representing the full path and file name of the drawing;
     Name is a string representing the name of external reference to be created;
     InsertionPoint is a Point object representing the point at which the drawing will be inserted;
     XScale, YScale, and ZScale are double-precision variables (or values) representing the scaling factors for the drawing along each coordinate plane;
     Rotation is a double-precision variable (or value) representing the rotation angle (in radians) for the external reference;
     bOverlay is a Boolean variable (or value) indicating whether the reference is an overlay or attachment
TRUE:     The xref instance is an overlay.
FALSE:     The xref instance is an attachment.
Examples...
AttachExternalReference method example
