GetBoundingBox method example
Sub GetBoundingBox_Example()
    Dim myText As String
    Dim textObj As AcadText
    Dim insPt(0 To 2) As Double
    Dim height As Double
    insPt(0) = 3: insPt(1) = 7: insPt(2) = 0
    height = 5
    myText = "Test string for bounding box"
    Set textObj = ThisDrawing.ModelSpace.AddText(myText, insPt, height)
    textObj.Update
    ThisDrawing.Application.ZoomExtents
    Dim LL As Variant
    Dim UR As Variant
    textObj.GetBoundingBox LL, UR
    MsgBox "The extents of the bounding box for the text are:" & Chr(13) & _
    "Lower Left: " & LL(0) & ", " & LL(1) & Chr(13) & "Max Extent: " & UR(0) & ", " & UR(1)
End Sub
| ©  Menhirs NV. All rights reserved. |
