GetWidth method example
Sub GetSetWidth_Example()
    Dim myLWP As AcadLWPolyline
    Dim myPoints(0 To 5) As Double
    myPoints(0) = 0: myPoints(1) = 0
    myPoints(2) = 3: myPoints(3) = 0
    myPoints(4) = 3: myPoints(5) = 4
    Set myLWP = ThisDrawing.ModelSpace.AddLightWeightPolyline(myPoints)
    myLWP.Closed = True
    myLWP.Update
    ThisDrawing.Application.ZoomExtents
    Dim sw As Double
    Dim ew As Double
    myLWP.GetWidth 2, sw, ew
    MsgBox "The starting width for the second segment is " & sw, , "Get/SetWidth Example"
    myLWP.SetWidth 2, 1.2, ew
    myLWP.Update
    MsgBox "The starting width for the second segment is now " & sw, , "Get/SetWidth Example "
End Sub
| ©  Menhirs NV. All rights reserved. |
