Offset method
Creates an offset entity at a given distance from another entity, + and - represent the two sides for offset.
Syntax
object.Offset(OffsetDistance)
Where:
     object is a BricsCAD entity;
     OffsetDistance is a double-precision variable (or value) representing the distance to offset the entity.
