SetInvisibleEdge method
Sets the visibility for a 3DFace edge at a given index.
Syntax
object.SetInvisibleEdge(Index, State)
Where:
     object is a  Viewport or PViewport object;
     Index is an Integer representing the index number of the face;
     State is a Boolean variable specifying whether the visibility is on (True) or off (False).
Examples...
SetInvisibleEdge method example
