Document object
Class AcadDocument
Member of BricscadApp
The Document object represents the active BricsCAD drawing. The active document (BricsCAD drawing) can be accessed using ThisDrawing in VBA or through the ActiveDocument property in VB.
To create or open a Document object, use the New or Open methods. To edit or query a Document object, use the following methods,  properties  and events:
Methods Properties Events
Activate Active Activate
AuditInfo ActiveDimStyle BeginClose
Close ActiveLayer BeginCommand
CopyObjects ActiveLayout BeginDocClose
EndUndoMark ActiveLinetype BeginDoubleClick
Export ActivePViewport BeginLisp
GetVariable ActiveSelectionSet BeginPlot
HandleToObject ActiveSpace BeginRightClick
Import ActiveTextStyle BeginSave
LoadShapeFile ActiveUCS BeginShortcutMenuCommand
New ActiveViewport BeginShortcutMenuDefault
ObjectIdToObject Application BeginShortcutMenuEdit
PurgeAll Blocks BeginShortcutMenuGrip
Regen Database BeginShortcutMenuOsnap
Save Dictionaries Deactivate
SaveAs DimStyles EndCommand
SendCommand ElevationModelSpace EndLisp
SetVariable ElevationPaperSpace EndPlot
StartUndoMark FileDependencies EndSave
Wblock FullName EndShortcutMenu
  Groups LayoutSwitched
  Height LispCancelled
  HWND ObjectAdded
  Layers ObjectErased
  Layouts ObjectModified
  Limits SelectionChanged
  Linetypes WindowChanged
  Materials WindowMovedOrResized
  ModelSpace
  MSpace
  Name
  ObjectSnapMode
  PaperSpace
  Path
  PickfirstSelectionSet
  Plot
  PlotConfigurations
  Preferences
  ReadOnly
  RegisteredApplications
  Saved
  SectionManager
  SelectionSets
  SummaryInfo
  Textstyles
  UserCoordinateSystems
  Utility
  Viewports
  Views
  Width
  WindowState
  WindowTitle
