Class AcadToolbars
Member of BricscadApp
The Toolbars collection represents all the toolbars loaded in the current BricsCAD session, some or all of which may be currently displayed in AutoCAD. To load an existing toolbar into the current session, load the menu group that contains the toolbar using the Load method. To create a new toolbar, use the Add method.
To edit or query Toolbars collection, use the following methods and properties:
Methods | Properties |
Add | Application |
Item | Count |
LargeButtons | |
Parent |
© Menhirs NV. All rights reserved. |
