Class AcadViewport
Member of BricscadDb
The Viewport object represents a window that displays all or part of a drawing's model space. To access the Viewport object, use the following methods and properties:
Methods | Properties |
Delete | Application |
GetExtensionDictionary | Center |
GetGridSpacing | Direction |
GetSnapSpacing | Document |
GetXData | GridOn |
SetGridSpacing | Handle |
SetSnapSpacing | HasExtensionDictionary |
SetView | Height |
SetXData | LowerLeftCorner |
Split | Name |
ZoomAll | OrthoOn |
ZoomCenter | Parent |
ZoomExtents | SnapBasePoint |
ZoomPickWindow | SnapOn |
ZoomScaled | SnapRotationAngle |
ZoomWindow | Target |
UCSIconAtOrigin | |
UCSIconOn | |
UpperRightCorner | |
Width |
© Menhirs NV. All rights reserved. |
