Color property
Sets or returns the color of an entity.
Colors can be set and read as numeric index values ranging from 0 to 256. For the standard seven colors and the ByBlock and ByLayer designations, you can also use constants shown below. The default color designation is ByLayer (0).
Syntax
integerVariable = object.Color
object.Color = <integer>
where:
     integerVariable is a variable for storing the color index value.
     object is the entity object for which you set or return the color.
Colors Constant Index Value
acByBlock
0
acByLayer
256
acRed
1
acYellow
2
acGreen
3
acCyan
4
acBlue
5
acMagenta
6
acWhite
7
Examples...
Color property example
