ContourLinesPerSurface property
Sets or returns the number of contour lines per surface for entities in a given document. The value of this property is stored in the ISOLINES system variable.
Syntax
integerVariable = object.ContourLinesPerSurface
object.ContourLinesPerSurface = <integer>
where:
     integerVariable is a variable for storing the number of contour lines.
     object is the  DocumentPreferences object.
Examples ...
ContourLinesPerSurface property example
