CursorSize property example
Sub CursorSize_Example()
Dim currCursorSize As Integer
Dim newCursorSize As Integer
Dim myPrefs As AcadPreferences
Set myPrefs = ThisDrawing.Application.preferences
currCursorSize = myPrefs.Display.CursorSize
MsgBox "The current value for CursorSize is " & currCursorSize
newCursorSize = 15
myPrefs.Display.CursorSize = newCursorSize
MsgBox "The new value for CursorSize is " & newCursorSize
myPrefs.Display.CursorSize = currCursorSize
MsgBox "The CursorSize value is reset to " & currCursorSize
End Sub
© Menhirs NV. All rights reserved. |
