HorizontalAlignment property example
Sub HorizontalAlignment_Example()
Dim insPt(0 To 2) As Double: insPt(0) = 0: insPt(1) = 9: insPt(2) = 0:
Dim dHeight As Double: dHeight = 5
Dim sText As String: sText = "Test string for the AddText method"
Dim oText As AcadText
Set oText = ThisDrawing.ModelSpace.AddText(sText, insPt, dHeight)
ReAlign oText, acHorizontalAlignmentLeft, acVerticalAlignmentBaseline
ReAlign oText, acHorizontalAlignmentCenter, acVerticalAlignmentBaseline
ReAlign oText, acHorizontalAlignmentRight, acVerticalAlignmentBaseline
ReAlign oText, acHorizontalAlignmentLeft, acVerticalAlignmentBottom
ReAlign oText, acHorizontalAlignmentLeft, acVerticalAlignmentMiddle
ReAlign oText, acHorizontalAlignmentLeft, acVerticalAlignmentTop
End Sub
Private Sub ReAlign(tt As AcadText, aH As AcHorizontalAlignment, aV As AcVerticalAlignment)
tt.HorizontalAlignment = aH
tt.VerticalAlignment = aV
tt.Update
Dim sBuf As String
sBuf = "HorizontalAlignment property is: " & tt.HorizontalAlignment
sBuf = sBuf & Chr(13) & "VerticalAlignment property is: " & tt.VerticalAlignment
MsgBox sBuf
End Sub
© Menhirs NV. All rights reserved. |
