Item property
Returns the member object at a given index in a collection, group, or selection set.
Syntax
objectVariable = object.Item(Index)
Where:
     objectVariable is a variable representing the Item property.
     object is the Application object;
     Index is a Long integer representing the index number of the item.
Examples...
Item property example
