Layer property
Sets or returns the layer of an entity. If you don't specify a layer, the current active layer is used for a new entity. If a layer is specified for an entity, the current active layer is ignored. Each layer has associated properties that can be set and queried through the Layer object.
Syntax
stringVariable = object.Layer
object.Layer = <string>
Where:
     stringVariable is a variable for storing the layer name.
     object is the applicable entity object;
     string is the name of a layer to be assigned to an entity.
Examples...
Layer property example
