MaxAutoCADWindow property
Sets or returns whether the BricsCAD window should be maximized on startup.
Syntax
BooleanVariable = object.object.MaxAutoCADWindow = <Boolean>
Where:
     BooleanVariable determines whether the window is maximized (True) or not (False).
     object is the ApplicationPreferences object.
Examples...
MaxAutoCADWindow property example
