PromptString property
Returns the prompt for an attribute definition. This string appears when a block containing this attribute is inserted.
Syntax
stringVariable = object.PromptString
Where:
     stringVariable represents the prompt string.
     object is the Attribute object.
Examples...
Attribute properties example
