URL property example
Sub HyperLinks_Example()
Dim oMtext As AcadMText
Dim sTextString As String
Dim insPt(0 To 2) As Double: insPt(0) = 0: insPt(1) = 9
sTextString = "\LSelect text, then right-click and use Hyperlink>Open"
Set oMtext = ThisDrawing.ModelSpace.AddMText(insPt, 18, sTextString)
oMtext.height = 1
oMtext.width = 18
oMtext.Update
ThisDrawing.Application.ZoomExtents
Dim Hyperlinks As AcadHyperlinks
Dim Hyperlink As AcadHyperlink
Set Hyperlinks = oMtext.Hyperlinks
Set Hyperlink = Hyperlinks.Add("Bricsys")
Hyperlink.URL = "http://www.bricsys.com/en_INTL/bricscad/"
Hyperlink.URLDescription = "The BricsCAD Site"
Hyperlink.URLNamedLocation = "BricsCAD"
Dim sBuf As String
For Each Hyperlink In Hyperlinks
sBuf = sBuf & "____________________________________" & vbCrLf
sBuf = sBuf & "URL: " & Hyperlink.URL & vbCrLf
sBuf = sBuf & "URL Description: " & Hyperlink.URLDescription & vbCrLf
sBuf = sBuf & "URL Named Location: " & Hyperlink.URLNamedLocation & vbCrLf
Next
MsgBox "The Mtext object has " & Hyperlinks.count & " Hyperlink: " & vbCrLf & sBuf
End Sub
© Menhirs NV. All rights reserved. |
