Visible property
Specifies visibility of a drawing object or  Application window.
Syntax
BooleanVariable = object.Visible
object.Visible = <boolean>
Where:
     BooleanVariable is a variable (True or False) specifying whether the object is visible or not.
     object is All Drawing objects, Application, AttributeReference, Group, Toolbar
Examples...
Visible property example
