Sub WindowTop_Example() ' This example finds the WindowTop of the Application window. It then ' increments that position and then resets it. Dim iWindowTop As Integer iWindowTop = ThisDrawing.Application.WindowTop MsgBox ("Current value of WindowTop is : " & iWindowTop) ' Increment the value of WindowTop ThisDrawing.Application.WindowTop = iWindowTop + 50 MsgBox "The new value of WindowTop is " & ThisDrawing.Application.WindowTop ' Reset original value of WindowTop ThisDrawing.Application.WindowTop = iWindowTop MsgBox "The value of WindowTop has been reset to " & ThisDrawing.Application.WindowTop End Sub
