bcad_height
The attribute bcad_height is a BricsCAD-only attribute. If it is specified, it is used instead of the attribute height to set a minimum height on any tile. This allows to bypass small cosmetic problems in the BricsCAD dcl engine. Since the BricsCAD dcl engine is implemented with wxWidgets, some small visual differences with an MFC based dcl engine cannot be avoided. This is however rarely needed and normally concerns details only.
related tiles
Most tiles can have a bcad_height attribute. It is ignored for a popup_list only.
