bcad_skip_next_child
This bricscad-only boolean attribute can be used to skip any dcl component that appears right behind it. Set the attribute to true at any nesting level. The next dcl element, be it a nested component or an attribute, will be skipped. Only the next element will be skipped.
This is particularly useful in combination with the attribute bcad_label> of a list_box.
related tiles
All of the tiles can have a bcad_skip_next_child attribute.
