tabs
This attribute can be used to control the width of columns in a DCL list control (list_box or popup_list). The value of this attribute has to be a string containing a space separated list of integers. For historic reasons these integers are cumulative, it is a list of increasing integers. Every integer adds the width of the next column to the previous cumulative width. So to specify four columns of width 5, use "5 10 15 20". Mind that there will be a fifth column of remaining width, so perhaps the last integer is not wanted.
related tiles
This attribute is predefined for a list_box and a popup_list.
