default_dcl_settings
This component is used to set the DCL "audit level". The audit level is a positive integer that controls the amount of error or warning messages that are displayed. See the attribute audit_level for an explanation about the different audit level values.
A settings element can be used to specify the audit level like this: dcl_settings : default_dcl_settings { audit_level = 0; }
related attributes
The attribute audit_level is the only predefined attribute for default_dcl_settings.
