A DCL slider is a child tile that shows a horizontal or vertical
line segment and a marker that can shift along the displayed line.
It represents an interval with a current position. The current
position can be changed by dragging the marker, by clicking the
displayed line, by clicking arrow buttons at both ends of the
displayed line, by using the cursor keys or by using page-down or
page-up.
related attributes
These attributes are predefined for a slider only:
max_value
The largest integer value that can
appear in the interval. It corresponds with the rightmost position
in a horizontal slider or with the topmost position in a vertical
slider. The default max_value is 1000.
min_value
The smallest integer value that can
appear in the interval. It corresponds with the leftmost position
in a horizontal slider or with the bottom position in a vertical
slider. The default min_value is 0.
small_increment
The number of units the scrollbar will
be changed when using the arrow keys, while dragging the marker or
when clicking the arrow buttons at both ends of the displayed line.
The default is one hundredth of the size of the interval.
big_increment
move up/down when using page up/down, or when clicking the
displayed line. The default is one tenth of the size of the
interval.
This attribute is predefined for a cluster or slider only:
layout
This attribute controls the
orientation of the slider. It can have one of two values: vertical
or horizontal. The default orientation of a slider is
horizontal.
These attributes are predefined for every child tile and
consequently for a slider as well:
mnemonic
is_tab_stop
These attributes are predefined for every tile and consequently
key
value
The value of a slider refers to its
current position.
tooltip
label
Use the label attribute to display a
label in front of a horizontal slider or above a vertical
slider.
fixed_height
fixed_width
alignment
width
bcad_width
height
bcad_height
is_enabled
callbacks
A callback with reason CBR_SELECT is triggered when the
position of the slider changes.
