spacer
A DCL spacer is a child tile that takes up some area of the dialog. It is used to influence layouting. No user interaction is possible through a spacer, so it has no callbacks.
related attributes
Being a child tile, all attributes predefined on a child tile are predefined on a spacer as well. however, since no action can be performed on a spacer, most attributes make little sense on a spacer.
