Activate a Network license manually
The BricsCAD license
activation always requires an Internet connection.
However, if your computer is not
connected to the Internet, the license can be activated manually
via another computer (which is connected to the Internet).
To activate a Network
license manually
- In the Start menu, click
the License Activation
shortcut. The Activate Network License
dialog box opens.
- Copy the full content of
the Computer Hostid field.
- With the Internet connected
computer, go to the Bricsys website
- In the Support menu, choose
My Account (login required).
Make sure you have the Bricsys account of your company which
contains the Volume license. Contact your Bricsys account manager
if needed.
The My Account page opens.
- In the left menu, choose Licenses and
support contracts.
- Click the Activate button of the license you want to activate.
- In the Host ID field, paste the computer host ID of the
computer you want to install BricsCAD on.
- In the
host ID of the computer you want to install BricsCAD on.
- Click the
Activate button.
A license file is generated and made available for
download.
- Click the
Download License File button.
The license file BricsCAD.lic is
downloaded to your default download folder.
- Copy the
license file to the server, in the Bricsys Network License Manager
installation folder (by default : C:\Program Files (x86)\Bricsys\Bricsys
Network License Manager).
NOTE
Manually activated licenses cannot be deactivated.
© Menhirs NV. All rights reserved. |
