Constructs 3D rectangular arrays and rotated polar arrays (short for "three dimensional array").
command bar: 3darray
aliases: 3a, array3d
menu bar: Modify | 3D Array
toolbar: Modify | ![]()
: 3darray
Select entities to array: (Choose one or more entities.)
Entities in set: 1
Select entities to array: (Choose more entities, or press Enter to continue.)
Type of array: Polar/<Rectangular>: (Type P or R.)
Rectangular array:
Number of rows in the array <1>: (Enter a number, or press Enter to accept the default.)
Number of columns <1>: (Enter a number, or press Enter to accept the default.)
Number of levels <1>: (Enter a number, or press Enter to accept the default.)
Vertical distance between rows: (Enter a number, or press Enter to accept the default.)
Horizontal distance between columns: (Enter a number, or press Enter to accept the default.)
Depth between levels: (Enter a number, or press Enter to accept the default.)
Polar array:
ENTER to specify angle between items/<Number of items to array>: (Enter a number, or press Enter.)
Angle to array (+ for ccw, - for cw) <360>: (Enter a number, or press Enter to accept the default.)
Rotate entities around the array? No/<Yes>: (Type Y or N.)
Center point of array: (Pick a point, or enter x,y,z coordinates.)
Specify second point along central axis of array: (Pick a point, or enter x,y,z coordinates.)
Specifies the entities to be arrayed. Use any entity selection method; press Enter when you are done. |
Creates polar (circular) arrays. |
Creates linear, rectangular, or square arrays. |
Rectangular Array Options |
Specifies the number of rows (x direction); for a linear array, enter 1. To draw the array downwards, enter a negative number. |
Specifies the number of columns (y direction). To draw the array to the left, enter a negative number. |
Specifies the number of levels (z direction). To draw the array downwards, enter a negative number. |
Specifies the distance between rows of entities. |
Specifies the distance between columns of entities. |
Specifies the distance between levels of entities. |
Procedures
Creating a 3D rectangular array
Array - creates 2D arrays.
MInsert - inserts arrays of blocks.
