Sets the properties for snap tracking, through the Settings dialog box (short for "dynamic dialog snap tracking").
command bar: ddstrack
transparent: 'ddstrack
alias: settings
status bar: STRACK
: ddstrack
Displays the Snap Tracking section of the Settings dialog box:
Change settings, and then click X.
AutoSnap |
Specifies the look and action of AutoSnap:
Polar Angle |
Specifies the default polar snap increment; default =15 degrees. |
Polar Add Angles |
Specifies additional user-defined angles for polar snap. |
Polar Mode |
Specifies how polar mode is handled:
Track Path |
Determines how the tracking path is displayed:
None.
